[GRASS5] can't display vector maps
Radim Blazek
blazek at itc.it
Fri Nov 19 05:00:08 EST 2004
Could you try
strace d.vect roads 2>&1 | grep access | grep roads
Radim
Otto Dassau wrote:
> On Fri, 19 Nov 2004 09:03:06 +0100
> Markus Neteler <neteler at itc.it> wrote:
>>Hi Otto,
>>Radim submitted a bunch of bugfixes yesterday early evening:
>>http://grass.itc.it/pipermail/grass-commit/2004-November/date.html#end
>>Please update again. I just tested and things seem to work ok now.
> Hi,
> it is the same problem. I can't display vector maps with the current CVS snapshot. Are you sure, it works with your maps
> Otto
>>GENERAL NOTES to update to current 5.7-CVS:
>>Probably there was a small bug in 'make mixclean' leaving
>>the links to 5.3 in the include/ directory. Please check
>>if grass57/include/ still contains links to GRASS 5.3-CVS
>>which is wrong. If links are still in existing in that
>>directory, run
>> find include -type l -exec rm {} \;
>>GRASS 5.7-CVS may no longer have links to 5.3-CVS.
>>Then:
>> make distclean
>> cvs up -dP
>> configure ...
>> make
>> make install
>>Hope this helps
>> Markus
>>On Thu, Nov 18, 2004 at 03:37:33PM +0100, Otto Dassau wrote:
>>>On Thu, 18 Nov 2004 09:52:26 +0100
>>>Otto Dassau <otto.dassau at gmx.de> wrote:
>>>>Dear list,
>>>Hi,
>>>I checked again, installed GRASS CVS from scratch with the same result. I hope this is a minor bug and will be fixed soon, otherwise it is impossible to work with vector data.
>>>I went back to CVS snapshot grass57_exp_2004_11_13, there it is still working.
>>> thanks
>>> Otto
>>>>I updated GRASS 5.7 from CVS this morning and can't display
>>>>vector maps anymore. I tried in several locations, with several maps.
>>>>I can see and select maps, but that's it.
>>>>GRASS 5.7.cvs:~ > g.list vect
>>>>vector files available in mapset PERMANENT:
>>>>archsites soils t_9961_300 t_county
>>>>bugsites soistr t_9961_300_all t_hydro
>>>>fields streams t_9961_300_bks t_powerlines
>>>>quads t_9961_100 t_9961_400 tractids
>>>>roads
>>>>GRASS 5.7.cvs:~ > d.vect roads
>>>>ERROR: Vector file [roads] not available
>>>>the more detailed error messageusing the GIS Manager is:
>>>>child process exited abnormally
>>>> while executing
>>>>"exec -- d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/cross size=5 fiel..."
>>>> ("eval" body line 1)
>>>> invoked from within
>>>>"eval exec -- $cmd $args >@ stdout 2>@ stderr"
>>>> (procedure "run" line 2)
>>>> invoked from within
>>>>"run $cmd"
>>>> (procedure "DmVector::display" line 77)
>>>> invoked from within
>>>>"DmVector::display $node"
>>>> ("vector" arm line 2)
>>>> invoked from within
>>>>"switch $type {
>>>> group {
>>>> DmGroup::display $node
>>>> raster {
>>>> DmRaster::display $node
>>>> labels {
>>>> DmLabels::display $node
>>>> (procedure "Dm::display_node" line 6)
>>>> invoked from within
>>>>"Dm::display_node $n"
>>>> (procedure "DmGroup::display" line 11)
>>>> invoked from within
>>>>"DmGroup::display "root""
>>>> (procedure "Dm::display" line 6)
>>>> invoked from within
>>>>"Dm::display"
>>>> ("uplevel" body line 1)
>>>> invoked from within
>>>>"uplevel \#0 $cmd"
>>>> (procedure "Button::_release" line 18)
>>>> invoked from within
>>>>"Button::_release .mainframe.topf.tb0.bbox1.b0"
>>>> (command bound to event)
>>>> Otto
>>>>_______________________________________________
>>>>grass5 mailing list
>>>>grass5 at grass.itc.it
>>>>http://grass.itc.it/mailman/listinfo/grass5
>>Markus Neteler <neteler itc it> http://mpa.itc.it
>>ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
>>MPBA - Predictive Models for Biol. & Environ. Data Analysis
>>Via Sommarive, 18 - 38050 Povo (Trento), Italy
> grass5 mailing list
