[GRASS5] can't display vector maps
Otto Dassau otto.dassau at gmx.de
Fri Nov 19 05:39:26 EST 2004
On Fri, 19 Nov 2004 11:00:08 +0100
Radim Blazek <blazek at itc.it> wrote:
> Could you try
> strace d.vect roads 2>&1 | grep access | grep roads
GRASS 5.7.cvs:~ > strace d.vect roads 2>&1 | grep access | grep roads
access("/daten/grassdata/spearfish57/PERMANENT/dig/roads", F_OK) = -1 ENOENT (No such file or directory)
  Otto
> Radim
> Otto Dassau wrote:
> > On Fri, 19 Nov 2004 09:03:06 +0100
> > Markus Neteler <neteler at itc.it> wrote:
> >>Hi Otto,
> >>Radim submitted a bunch of bugfixes yesterday early evening:
> >>http://grass.itc.it/pipermail/grass-commit/2004-November/date.html#end
> >>Please update again. I just tested and things seem to work ok now.
> > Hi,
> > it is the same problem. I can't display vector maps with the current CVS snapshot. Are you sure, it works with your maps
> >   Otto
> >>GENERAL NOTES to update to current 5.7-CVS:
> >>Probably there was a small bug in 'make mixclean' leaving
> >>the links to 5.3 in the include/ directory. Please check
> >>if grass57/include/ still contains links to GRASS 5.3-CVS
> >>which is wrong. If links are still in existing in that
> >>directory, run
> >>  find include -type l -exec rm {} \;
> >>GRASS 5.7-CVS may no longer have links to 5.3-CVS.
> >>Then:
> >>  make distclean
> >>  cvs up -dP
> >>  configure ...
> >>  make
> >>  make install
> >>Hope this helps
> >> Markus
> >>On Thu, Nov 18, 2004 at 03:37:33PM +0100, Otto Dassau wrote:
> >>>On Thu, 18 Nov 2004 09:52:26 +0100
> >>>Otto Dassau <otto.dassau at gmx.de> wrote:
> >>>>Dear list,
> >>>Hi,
> >>>I checked again, installed GRASS CVS from scratch with the same result. I hope this is a minor bug and will be fixed soon, otherwise it is impossible to work with vector data.
> >>>I went back to CVS snapshot grass57_exp_2004_11_13, there it is still working.
> >>>  thanks
> >>>   Otto
> >>>>I updated GRASS 5.7 from CVS this morning and can't display
> >>>>vector maps anymore. I tried in several locations, with several maps.
> >>>>I can see and select maps, but that's it.
> >>>>GRASS 5.7.cvs:~ > g.list vect
> >>>>vector files available in mapset PERMANENT:
> >>>>archsites     soils           t_9961_300      t_county
> >>>>bugsites      soistr          t_9961_300_all  t_hydro
> >>>>fields        streams         t_9961_300_bks  t_powerlines
> >>>>quads         t_9961_100      t_9961_400      tractids
> >>>>roads
> >>>>GRASS 5.7.cvs:~ > d.vect roads
> >>>>ERROR: Vector file [roads] not available
> >>>>the more detailed error messageusing the GIS Manager is:
> >>>>child process exited abnormally
> >>>>    while executing
> >>>>"exec -- d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/cross size=5 fiel..."
> >>>>    ("eval" body line 1)
> >>>>    invoked from within
> >>>>"eval exec -- $cmd $args >@ stdout 2>@ stderr"
> >>>>    (procedure "run" line 2)
> >>>>    invoked from within
> >>>>"run $cmd"
> >>>>    (procedure "DmVector::display" line 77)
> >>>>    invoked from within
> >>>>"DmVector::display $node"
> >>>>    ("vector" arm line 2)
> >>>>    invoked from within
> >>>>"switch $type {
> >>>>        group {
> >>>>            DmGroup::display $node
> >>>>	raster {
> >>>>	    DmRaster::display $node
> >>>>	labels {
> >>>>	    DmLabels::display $node
> >>>>    (procedure "Dm::display_node" line 6)
> >>>>    invoked from within
> >>>>"Dm::display_node $n"
> >>>>    (procedure "DmGroup::display" line 11)
> >>>>    invoked from within
> >>>>"DmGroup::display "root""
> >>>>    (procedure "Dm::display" line 6)
> >>>>    invoked from within
> >>>>"Dm::display"
> >>>>    ("uplevel" body line 1)
> >>>>    invoked from within
> >>>>"uplevel \#0 $cmd"
> >>>>    (procedure "Button::_release" line 18)
> >>>>    invoked from within
> >>>>"Button::_release .mainframe.topf.tb0.bbox1.b0"
> >>>>    (command bound to event)
> >>>>   Otto
> >>>>_______________________________________________
> >>>>grass5 mailing list
> >>>>grass5 at grass.itc.it
> >>>>http://grass.itc.it/mailman/listinfo/grass5
> >>Markus Neteler     <neteler itc it>       http://mpa.itc.it
> >>ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> >>MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >>Via Sommarive, 18        -       38050 Povo (Trento), Italy
> > grass5 mailing list
