[GRASS5] can't display vector maps
    Radim Blazek
    blazek at itc.it
    Fri Nov 19 06:37:41 EST 2004
You are running 5.7 modules with 5.0/3 libs.
Radim
Otto Dassau wrote:
> On Fri, 19 Nov 2004 11:00:08 +0100
> Radim Blazek <blazek at itc.it> wrote:
>>Could you try
>>strace d.vect roads 2>&1 | grep access | grep roads
> Hi,
> GRASS 5.7.cvs:~ > strace d.vect roads 2>&1 | grep access | grep roads
> access("/daten/grassdata/spearfish57/PERMANENT/dig/roads", F_OK) = -1 ENOENT (No such file or directory)
>   Otto
