[GRASS5] v.in.db segfault and sql problems
Joel Peter William Pitt pittj2 at lincoln.ac.nz
Tue Nov 23 18:19:09 EST 2004
Thanks Radim, that was the problem :)
(Also thanks Hamish for offering me a work around!)
As an aside, when one runs grass and specifies
a mapset directory on the command line, is there
any reason why using "." (current directory)
shouldn't work? I ask because g.mapsets -l
complains that the directory can't be "." or NULL.
Thanks,
Joel
P.S. My Open Source GIS textbook just arrived, yay!
Radim Blazek wrote:
> 'DATE' is SQL reserved word, try to rename that column.
