[GRASS5] adapting locations to 57, nviz updates
Glynn Clements
glynn at gclements.plus.com
Fri Nov 19 11:27:16 EST 2004
Helena wrote:
> Glynn, how does r3.mapcalc handle situation when
> the region defined in WIND3 has different resolution from the 3d
> raster(s) used in mapcalc - is there 3d resampling?
I don't know. It uses G3d_getValueRegion(); is that in the region's
coordinates or the map's coordinates? The g3d documentation isn't
exactly clear.
It *should* be resampling the data; if it isn't, then I need to use
G3d_getValue() instead.
