[GRASS5] [bug #2710] (grass) import mrSid
Markus Neteler neteler at itc.it
Tue Nov 23 08:27:55 EST 2004
On Tue, Nov 23, 2004 at 09:03:53AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2710
> Subject: import mrSid
> I want to import images mrSid... Somebody knows if there is a library for
> Grass 5.7 that supports this format?
> Thanks!
> Lourdes
GDAL support MrSID:
 http://gdal.org/frmt_mrsid.html
Note that MrSID is not a free algorithm. You need to obtain a license
to compile GDAL with MrSID support.
Then r.in.gdal should read such data.
Markus
