[GRASS5] [bug #2710] (grass) import mrSid
Stephen Clark
stephen.clark at focus.ca
Tue Nov 23 10:39:08 EST 2004
Another alternative is to export the SID file to TIF + TFW and import with
r.in.gdal
It is not the solution you may want but it could work in the short term.
Stephen
----- Original Message -----
From: "Request Tracker" <grass-bugs at intevation.de>
To: <grass5 at grass.itc.it>
Sent: Tuesday, November 23, 2004 1:03 AM
Subject: [GRASS5] [bug #2710] (grass) import mrSid
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2710
> Subject: import mrSid
> I want to import images mrSid... Somebody knows if there is a library for
> Grass 5.7 that supports this format?
> Thanks!
> Lourdes
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
