[GRASS5] v.out.ascii: Segmentation fault
Jachym Cepicky
jachym.cepicky at centrum.cz
Wed Nov 24 07:51:58 EST 2004
Hallo,
it's going to be interesting...
On Wed, Nov 24, 2004 at 11:45:31AM +0100, Markus Neteler wrote:
> On Wed, Nov 24, 2004 at 09:26:47AM +0100, Jachym Cepicky wrote:
> cd grass57
> find . -type l
> # ... should only report the .so links of the libgrass_xxx files.
> If needed, remove all links to 5.3-CVS ('make mixclean' should do
> that), then update again from CVS and recompile again.
> There was a bug in the 'make mixclean' routine which probably
> left over some links.
cd /usr/src/grass
rm -rf grass51
# should solve this (?)
cvs -z3 co grass51
cd grasss51
./configure --with-grass50=/usr/src/grass/grass/ --with-tcltk-includes=/usr/include/tcl8.4/ --with-postgres-includes=/usr/include/postgresql/ --with-freetype --with-freetype --with-freetype-includes=/usr/include/freetype2/ --with-readline
make
Started compilation: St lis 24 12:44:56 CET 2004
Errors in:
/usr/src/grass/grass51/raster3d/r3.showdspf
Finished compilation: St lis 24 12:58:17 CET 2004
checkinstall -D
OK, run grass57 and than
> If it still fails, run (in every mapset)
> v.build.all
> to rebuild the topology.
GRASS 5.7.cvs:~ >v.rebuild.all
GRASS 5.7.cvs:~ > v.out.ascii novy
Segmentation fault
GRASS 5.7.cvs:~ > d.vect novy
(no problem)
but there occurres another problem:
GRASS 5.7.cvs:~ > nviz elev=dem
WARNING: G3d_readWindow: unable to find
[/home/jachym/grassdata/krtiny/mapserv/WIND3], using default.
[/home/jachym/grassdata/krtiny/PERMANENT/DEFAULT_WIND3].
FATAL ERROR: G3d_initDefaults: Error reading window
GRASS 5.7.cvs:~ > g3.createwind b=0 t=1000 dres=1
Loading Data
Loading Data
translating colors
Xlib: extension "XFree86-DRI" missing on display ":0.0".
recalculating normals...
Segmentation fault
GRASS 5.7.cvs:~ >
> If it then still fails, please report again.
Well, it didn't help :-(
System: debian, testing
what other info do you need?
Thank You
Jáchym
P.S.: I know, that now I mix two things in one email. Sorry for that, but I
thing it is better now, to have this all together.
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041124/157443cd/attachment.bin
