[GRASS5] d.m - d.what.vect
Michael Barton
michael.barton at asu.edu
Wed Nov 24 09:48:40 EST 2004
The form mode does not work correctly at least for ALL Mac users.
That is, it works once per GRASS session then doesn't work again until GRASS
is restarted. This has been a problem for over a year (since I first got 5.7
working on a Mac). I also heard that some Linux users cannot use form mode,
but I'm not sure about that. I don't know about Cygwin as it has been
problematic under 5.7 until recently.
The way I have it set up now is that selecting d.what.vect (query with
mouse) from the menus in d.m it goes to the standard tcltk dialog where the
user can choose whether or not to use form mode. I think GUI form mode is
the default.
The only place I 'hard coded' -x mode is into the toolbar icon because in
that way, the simple query tool will do a simple successful query on all
systems. It also has the same look and behavior whether you pick a raster or
vector to query (currently there is no equivalent to form mode for
d.what.rast).
Michael
On 11/24/04 3:02 AM, "Radim Blazek" <blazek at itc.it> wrote:
> and we can discuss if the check box should be default on or off.
> I believe that people using d.m usually also wants to use GUI
> for d.what.vect, so I think, that the default value for that checkbox
> should be off if it works for more users than it doesn't.
> How many users do have the problem with form?
______________________________
Michael Barton, Professor of Anthropology
School of Human, Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
