[GRASS5] [bug #2719] (grass) .grassrc57 syntax
Markus Neteler via RT grass-bugs at intevation.de
Thu Nov 25 08:59:12 EST 2004
> > grass5.7.cvs-i686-pc-linux-gnu-24_11_2004/docs/html/variables.html:
> >   To permanently predefine GRASS variables the user may specify the
> >   variable(s) in the .grassrc57 file.
> We shouldn't be recommending that the user manually modifies that
> file. The official mechanism is to use g.gisenv.
Above quotation was incomplete. The page states:
 Setting GRASS variables
 You have to use "g.gisenv" ...
Anyway, I have modified it slightly.
Markus
-------------------------------------------- Managed by Request Tracker
