[GRASS5] Problem with d.mon under grass5.4
Thu Nov 25 18:42:31 EST 2004
Damiano Triglione wrote:
> I installed grass 5.4 with options without:
> postgres,mysql,odbc,fftw,proj,gdal,opengl,tiff,tcltk,png because I
> thought it was quicker for me and I did not need them.
> Unfortunately, when I type
>    d.mon start=x0
> I have the following error message:
> Could not execute monitor: No such file or directory
> No socket to connect to for monitor <x0>.
> Problem selecting x0. Will try once more
> If anyone can help me to understand which options should I include
> to recompile grass correctly and let me understand if there is a way
> to compile only the missing libraries, I will appreciate.
It isn't necessarily related to configure options. If you look in the
error.log it will probably indicate that there was an error in
src/display/devices/XDRIVER. You will need to examine the output from
"make" to determine the actual error.
