[GRASS5] no links to GRASS 5.4 binaries
Glynn Clements
glynn at gclements.plus.com
Thu Nov 25 19:02:28 EST 2004
Markus Neteler wrote:
> > >Is there any volunteer to compile 5.4 binaries (Linux etc)?
> > i have compiled 5.4 with this configure output:
> > PostgreSQL support: yes
Do we still have the rule that NVIZ should be built without PostgreSQL
support?
> > Motif support: no
> > FreeType support: yes
> > GLw support: no
> With Motif and GLw "yes" a few more modules would be
> available (r3.something and xganim).
xganim requires Motif; r3.showdspf requires Motif and GLw.
> > NLS support: no
Is there any reason do disable NLS on Linux? It shouldn't require any
additional libraries (the gettext family are part of GNU libc).
> > Readline support: yes
This is a bad idea. On a number of Linux distributions, libreadline
requires a termcap library (libtermcap, libtinfo, or lib[n]curses),
but doesn't list one as a dependency.
On those platforms, an r.mapcalc binary which uses readline won't
work, which is a serious problem.
The --with-readline switch should only be used if you're building for
yourself, or for a specific distribution where that switch is known to
work.
