[GRASS5] no links to GRASS 5.4 binaries
Florian Goessmann florian at wallweg39.de
Fri Nov 26 02:41:37 EST 2004
>>> i have compiled 5.4 with this configure output:
>>>   PostgreSQL support:         yes
> Do we still have the rule that NVIZ should be built without PostgreSQL
> support?
when i switch postgreSQL og i get this:
Compilation error in module: src.contrib/GMSL/NVIZ2.2
>>>   Motif support:              no
>>>   FreeType support:           yes
>>>   GLw support:                no
>> With Motif and GLw "yes" a few more modules would be
>> available (r3.something and xganim).
> xganim requires Motif; r3.showdspf requires Motif and GLw.
>>>   NLS support:                no
> Is there any reason do disable NLS on Linux? It shouldn't require any
> additional libraries (the gettext family are part of GNU libc).
it doesn't. i switched it on.
>>>   Readline support:           yes
> This is a bad idea. On a number of Linux distributions, libreadline
> requires a termcap library (libtermcap, libtinfo, or lib[n]curses),
> but doesn't list one as a dependency.
> On those platforms, an r.mapcalc binary which uses readline won't
> work, which is a serious problem.
> The --with-readline switch should only be used if you're building for
> yourself, or for a specific distribution where that switch is known to
> work.
without readine support i get an error on my system:
Compilation error in module: src/raster/r.mapcalc3
florian
