[GRASS5] no links to GRASS 5.4 binaries
Fri Nov 26 04:38:50 EST 2004
Florian Goessmann wrote:
> when i switch postgreSQL og i get this:
> Compilation error in module: src.contrib/GMSL/NVIZ2.2
> without readine support i get an error on my system:
> Compilation error in module: src/raster/r.mapcalc3
You need to run "make clean" (or maybe "make distclean") before
re-running configure with different options.
