[GRASS5] no links to GRASS 5.4 binaries
Glynn Clements
glynn at gclements.plus.com
Fri Nov 26 15:34:06 EST 2004
> >>>> when i switch postgreSQL og i get this:
> >>>> Compilation error in module: src.contrib/GMSL/NVIZ2.2
> >>>> without readine support i get an error on my system:
> >>>> Compilation error in module: src/raster/r.mapcalc3
> >>> You need to run "make clean" (or maybe "make distclean") before
> >>> re-running configure with different options.
> >> i did that.
> > So what are the actual error messages you get when you build with
> > those options disabled?
> r.mapcalc3:
> /home/florian/Documents/SRCes/grass-5.4.0/build/src/raster/r.mapcalc3/
> lex.yy.o(.text+0x11f7): In function `yy_get_next_buffer':
> /home/florian/Documents/SRCes/grass-5.4.0/src/raster/r.mapcalc3/
> mapcalc.l:58: undefined reference to `readline'
Line 58 of mapcalc.l is within a block which is conditionalised upon
HAVE_READLINE_READLINE_H:
#ifdef HAVE_READLINE_READLINE_H
if (isatty(fileno(input_stream)))
char *line_read;
line_read = readline("mapcalc> ");
The error indicates that the build is trying to use an object file
from a previous build attempt, when --with-readline was used.
You need to clean up the previous build. If you used the gmake build
mechanism (--enable-gmake), "make distclean" should do this. If you
used the alternate build mechanism (--disable-gmake, which should be
the default for 5.4), simply delete the entire build directory (with
"rm -rf").
> nviz:
> *** PostgreSQL unsupported ***
> /home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/
> NVIZ2.2/src/runPg.o(.text+0x12c):
> In function `runPg':
> /home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/
> runPg.c:34:
> undefined reference to `PQsetdbLogin'
Same error (trying to use object files from a previous build with
different configure switches).
