[GRASS5] no links to GRASS 5.4 binaries
Florian Goessmann
florian at wallweg39.de
Sun Nov 28 12:29:52 EST 2004
On 26/11/2004, at 9:34 PM, Glynn Clements wrote:
>> r.mapcalc3:
>> /home/florian/Documents/SRCes/grass-5.4.0/build/src/raster/r.mapcalc3/
>> lex.yy.o(.text+0x11f7): In function `yy_get_next_buffer':
>> /home/florian/Documents/SRCes/grass-5.4.0/src/raster/r.mapcalc3/
>> mapcalc.l:58: undefined reference to `readline'
> Line 58 of mapcalc.l is within a block which is conditionalised upon
> HAVE_READLINE_READLINE_H:
> #ifdef HAVE_READLINE_READLINE_H
> if (isatty(fileno(input_stream)))
> char *line_read;
> line_read = readline("mapcalc> ");
> The error indicates that the build is trying to use an object file
> from a previous build attempt, when --with-readline was used.
> You need to clean up the previous build. If you used the gmake build
> mechanism (--enable-gmake), "make distclean" should do this. If you
> used the alternate build mechanism (--disable-gmake, which should be
> the default for 5.4), simply delete the entire build directory (with
> "rm -rf").
that's what i thought when i checked the source, but deleting the whole
build directory didn't solve it.
regards
