[GRASS5] no links to GRASS 5.4 binaries
Glynn Clements
glynn at gclements.plus.com
Sun Nov 28 20:30:23 EST 2004
Florian Goessmann wrote:
> >> r.mapcalc3:
> >> /home/florian/Documents/SRCes/grass-5.4.0/build/src/raster/r.mapcalc3/
> >> lex.yy.o(.text+0x11f7): In function `yy_get_next_buffer':
> >> /home/florian/Documents/SRCes/grass-5.4.0/src/raster/r.mapcalc3/
> >> mapcalc.l:58: undefined reference to `readline'
> > Line 58 of mapcalc.l is within a block which is conditionalised upon
> > HAVE_READLINE_READLINE_H:
> > #ifdef HAVE_READLINE_READLINE_H
> > if (isatty(fileno(input_stream)))
> > char *line_read;
> > line_read = readline("mapcalc> ");
> > The error indicates that the build is trying to use an object file
> > from a previous build attempt, when --with-readline was used.
> > You need to clean up the previous build. If you used the gmake build
> > mechanism (--enable-gmake), "make distclean" should do this. If you
> > used the alternate build mechanism (--disable-gmake, which should be
> > the default for 5.4), simply delete the entire build directory (with
> > "rm -rf").
> that's what i thought when i checked the source, but deleting the whole
> build directory didn't solve it.
It may be that some files (e.g. include/config.h) are left over in the
source directory from your original gmake-based build. Re-run
configure from the source directory with --enable-gmake, then run
"make maintainer-clean". Then do a non-gmake build.
It definitely works without --enable-readline, and binary
distributions should be built without that switch.
