[GRASS5] no links to GRASS 5.4 binaries
Florian Goessmann florian at wallweg39.de
Mon Nov 29 03:56:01 EST 2004
On 29/11/2004, at 2:30 AM, Glynn Clements wrote:
>> that's what i thought when i checked the source, but deleting the
>> whole
>> build directory didn't solve it.
> It may be that some files (e.g. include/config.h) are left over in the
> source directory from your original gmake-based build. Re-run
> configure from the source directory with --enable-gmake, then run
> "make maintainer-clean". Then do a non-gmake build.
> It definitely works without --enable-readline, and binary
> distributions should be built without that switch.
i compiled it again from a "freshly" unzipped source and it now works.
you can get the binary package and the installer script at
www.geographen.org/files.htm
regards
florian
