[GRASS5] no links to GRASS 5.4 binaries
Markus Neteler
neteler at itc.it
Mon Nov 29 04:36:28 EST 2004
On Mon, Nov 29, 2004 at 09:56:01AM +0100, Florian Goessmann wrote:
> On 29/11/2004, at 2:30 AM, Glynn Clements wrote:
> >>that's what i thought when i checked the source, but deleting the
> >>whole
> >>build directory didn't solve it.
> >It may be that some files (e.g. include/config.h) are left over in the
> >source directory from your original gmake-based build. Re-run
> >configure from the source directory with --enable-gmake, then run
> >"make maintainer-clean". Then do a non-gmake build.
> >It definitely works without --enable-readline, and binary
> >distributions should be built without that switch.
> i compiled it again from a "freshly" unzipped source and it now works.
> you can get the binary package and the installer script at
> www.geographen.org/files.htm
> regards
Thanks, Florian.
The files are posted now:
http://grass.itc.it/grass54/binary/linux/
(available on the mirrors in 0-2 days)
Markus
