[GRASS5] v.patch in 5.7 problems
Maciek Sieczka
werchowyna at pf.pl
Sat Nov 27 16:08:00 EST 2004
grass57_exp_2004_11_13
After merging a vector consisted of points with a vector consisted of lines
using v.patch I get a file where some lines and points are assigned the same
"field:" and "category:". It unables me create a database which would assign
the elevation values to both points and contour lines at one time! And I
need it to be done so in order to interpolate this "merged" elevation
information in one turn with v.surf.rst. Both input files had a nice
database.
BTW - why doesn't the v.patch create a merged database for the output file
while in 5.5 the v.patch copies all the input's cats and labels to the
output?
Please somebody answer and let me know if it's a bug worthy of a bug report.
Maciek Sieczka
