[GRASS5] v.patch in 5.7 problems
Radim Blazek
blazek at itc.it
Mon Nov 29 03:50:19 EST 2004
Maciek Sieczka wrote:
> grass57_exp_2004_11_13
> After merging a vector consisted of points with a vector consisted of
> lines using v.patch I get a file where some lines and points are
> assigned the same "field:" and "category:". It unables me create a
> database which would assign the elevation values to both points and
> contour lines at one time! And I need it to be done so in order to
> interpolate this "merged" elevation information in one turn with
> v.surf.rst. Both input files had a nice database.
> BTW - why doesn't the v.patch create a merged database for the output
> file while in 5.5 the v.patch copies all the input's cats and labels to
> the output?
> Please somebody answer and let me know if it's a bug worthy of a bug
> report.
It is wish report.
Radim
