[GRASS5] [bug #2733] (grass) note v.convert in UPGRADING
Radim Blazek
blazek at itc.it
Mon Nov 29 04:18:29 EST 2004
Maybe you want to get CVS access and fix that. I have more important
things on my TODO with higher priority.
Radim
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2733
> doc/vector/vector.html should say how to convert one's old vector file
> to new vector files, and visa versa.
> Indeed I was sure your vector commands were broken until one day I
> used (Debian bullhorn.org) g.list and noticed "oldvect"!
> There is no way returning users will know you changed the vector
> format unless you tell the whole story in some UPGRADING file, like
> spamassassin has.
> Anyway, how do I convert my old 5.0 vector files to new ones?
> Or maybe one just copies them over or something.
> Wait, deep down in the 2002 Blazek conference paper do I finally
> notice v.convert. Just wanted to let you know the story.
> P.S., $ v.convert help
> Description: Converts between GRASS vector versions.
> Say which versions. Indeed prepare for future versions...
> Say how to convert backwards too.
> P.S., mention all the new restrictions on vector file names there too!
> Also mention how to convert most or all of ones files in one step, not
> just one at a time. Especially as the names will probably need removal
> of now illegal chars.
> --- Headers Follow ---
>>From jidanni at jidanni.org Mon Nov 29 00:29:49 2004
> Return-Path: <jidanni at jidanni.org>
> Delivered-To: grass-bugs at lists.intevation.de
> Received: from mail.intevation.de (aktaia [212.95.126.10])
> by lists.intevation.de (Postfix) with ESMTP id EDEA6100179
> for <grass-bugs at lists.intevation.de>; Mon, 29 Nov 2004 00:29:48 +0100 (CET)
> Received: from localhost (localhost [127.0.0.1])
> by mail.intevation.de (Postfix) with ESMTP id A80DB36CE0
> Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
> by mail.intevation.de (Postfix) with ESMTP id 2760736DEF
> for <grass-bugs at intevation.de>; Mon, 29 Nov 2004 00:29:46 +0100 (CET)
> Received: from tc218-187-74-98.2-3.dynamic.apol.com.tw ([218.187.74.98]:33143 helo=jidanni1)
> by frodo.hserus.net with esmtpsa
> (Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
> id 1CYYU9-0000TI-TN by authid <jidanni> with plain
> for <grass-bugs at intevation.de>; Mon, 29 Nov 2004 04:59:42 +0530
> To: grass-bugs at intevation.de
> Subject: note v.convert in UPGRADING
> From: Dan Jacobson <jidanni at jidanni.org>
> Date: Mon, 29 Nov 2004 07:26:36 +0800
> Message-ID: <87k6s5wo5v.fsf at jidanni.org>
> MIME-Version: 1.0
> Content-Type: text/plain; charset=us-ascii
> X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
> X-Spam-Level:
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
