[GRASS5] v.out.ascii: Segmentation fault
Jachym Cepicky jachym.cepicky at centrum.cz
Mon Nov 29 10:00:08 EST 2004
On Mon, Nov 29, 2004 at 01:09:33PM +0100, Markus Neteler wrote:
> On Mon, Nov 29, 2004 at 01:07:40PM +0100, Jachym Cepicky wrote:
> > On Thu, Nov 25, 2004 at 02:01:21PM +0100, Markus Neteler wrote:
> > > > ./configure --with-cxx   --with-postgres-includes=/usr/include/postgresql/   --with-gdal=/usr/local/bin/gdal-config   --with-proj   --with-motif   --with-glw   --with-nls   --with-freetype  --with-freetype-includes=/usr/include/freetype2 --with-tcltk-includes=/usr/include/tcl8.4/
> > > SO: did configure report to have found Motif and glw and GL etc?
> > checking whether to use Motif... yes
> > checking for location of Motif includes...
> > checking for Xm/Xm.h... yes
> > checking for location of Motif library...
> > checking for XmStringCreate in -lXm... yes
> > checking whether to use GLw... yes
> > checking for location of GLw includes...
> > checking for GL/GLwMDrawA.h... yes
> > checking for location of GLw library...
> > checking for GLwCreateMDrawingArea in -lGLw... no
> > checking for GLwCreateM1DrawingArea in -lGLw... yes
> >  Source directory:            /usr/src/grass/grass51
> >  Build directory:             /usr/src/grass/grass51
> >  Installation directory:      /usr/local/grass-5.7.cvs
> >  Startup script in directory: ${exec_prefix}/bin
> >  C compiler:                  gcc -g -O2
> >  C++ compiler:                c++ -g -O2
> >  FORTRAN compiler:            g77
> >  Building shared libraries:   yes
> >   NVIZ:                       yes
> >   X11 support:                yes
> >   JPEG support:               yes
> >   TIFF support:               yes
> >   PNG support:                yes
> >   Tcl/Tk support:             yes
> >   PostgreSQL support:         yes
> >   MySQL support:              no
> >   OpenGL(R) support:          yes
> >   ODBC support:               yes
> >   FFTW support:               yes
> >   BLAS support:               no
> >   LAPACK support:             no
> >   Motif support:              yes
> >   FreeType support:           yes
> >   GLw support:                yes
> >   NLS support:                yes
> >   Readline support:           no
> >   C++ support:                yes
> >   openDWG support:            no
> >   GDAL support:               yes
> >   OGR support:                no
> There is something odd:
>  OGR support: should be YES
> > I would say, they are there.
> Looks like a partially broken GDAL installation.
> What does
>  ogrinfo --formats
> say?
> Markus
ogrinfo --formats
Loaded OGR Format Drivers:
  -> "ESRI Shapefile" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "MapInfo File" (read/write)
  -> "DGN" (read/write)
  -> "VRT" (readonly)
  -> "AVCBin" (readonly)
  -> "REC" (readonly)
  -> "Memory" (read/write)
  -> "GML" (read/write)
  -> "ODBC" (read/write)
  -> "PostgreSQL" (read/write)
and  following gdal* packages are installed:
gdal-bin
libgdal1
libgdal1-dev
(debian testing)
Jáchym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041129/fffecd9d/attachment.bin
