[GRASS5] v.out.ascii: Segmentation fault
Markus Neteler
neteler at itc.it
Mon Nov 29 10:53:56 EST 2004
On Mon, Nov 29, 2004 at 04:00:08PM +0100, Jachym Cepicky wrote:
> On Mon, Nov 29, 2004 at 01:09:33PM +0100, Markus Neteler wrote:
> > On Mon, Nov 29, 2004 at 01:07:40PM +0100, Jachym Cepicky wrote:
> > > On Thu, Nov 25, 2004 at 02:01:21PM +0100, Markus Neteler wrote:
> > > GDAL support: yes
> > > OGR support: no
> > There is something odd:
> > OGR support: should be YES
> ogrinfo --formats
> Loaded OGR Format Drivers:
> -> "ESRI Shapefile" (read/write)
> -> "UK .NTF" (readonly)
> and following gdal* packages are installed:
> gdal-bin
> libgdal1
> libgdal1-dev
> (debian testing)
What does
gdal-config --ogr-enabled
say? Should say 'yes'. Otherwise GDAL (or gdal-config) seems
to be broken on your system.
Markus
