[GRASS5] [bug #2742] (grass) file names cut off on snapshot
web page
Moritz Lennert
mlennert at club.worldonline.be
Tue Nov 30 02:53:46 EST 2004
On Tue, November 30, 2004 0:51, Request Tracker said:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2742
> On http://grass.itc.it/grass57/binary/linux/snapshot/ it says
> 1. get the file
> grass-5.7.cvs-ARCH-DD_MM_YYYY.tar.gz
> 2. get the installation script
> grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh
> However, above it, the file names are cut off:
> [ ] grass-5.7.cvs-i686-p..> 24-Nov-2004 22:54 9k
> [ ] grass-5.7.cvs-i686-p..> 24-Nov-2004 22:54 7.4M
> so one has to use extra sensory perception (ESP) and other clues to
> tell them apart.
> Or you might want to make the
> into links themselves.
Almost any browser should show you the complete link in a status bar (in
Mozilla and Konqueror this is at the bottom of the screen by default) or
similar when passing over the link with the cursor.
If you use lynx, then just type '=' when over the link and you will again see
the complete name under the heading 'Link that you currently have selected'. I
am sure that other text-based browsers have similar commands.
Moritz
