[GRASS5] [bug #2742] (grass) file names cut off on snapshot web page
Request Tracker grass-bugs at intevation.de
Mon Nov 29 18:51:48 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2742
On http://grass.itc.it/grass57/binary/linux/snapshot/ it says
   1.  get the file
      grass-5.7.cvs-ARCH-DD_MM_YYYY.tar.gz
   2. get the installation script
      grass-5.7.cvs-ARCH-DD_MM_YYYY-install.sh
However, above it, the file names are cut off:
[   ] grass-5.7.cvs-i686-p..> 24-Nov-2004 22:54     9k
[   ] grass-5.7.cvs-i686-p..> 24-Nov-2004 22:54   7.4M
so one has to use extra sensory perception (ESP) and other clues to
tell them apart.
Or you might want to make the
into links themselves.
--- Headers Follow ---
>From jidanni at jidanni.org  Tue Nov 30 00:51:47 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id DAC14100169
	for <grass-bugs at lists.intevation.de>; Tue, 30 Nov 2004 00:51:47 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 4E16936F13
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id E3F1236DE2
	for <grass-bugs at intevation.de>; Tue, 30 Nov 2004 00:51:45 +0100 (CET)
Received: from [218.187.75.215] (port=33526 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
	id 1CYvJ1-0003t1-Ps by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Tue, 30 Nov 2004 05:21:44 +0530
To: grass-bugs at intevation.de
Subject: file names cut off on snapshot web page
Date: Tue, 30 Nov 2004 06:00:22 +0800
Message-ID: <87ekicb9jd.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
