[GRASS5] troubles compiling v.in.ogr, sites, et al.
Glynn Clements
glynn at gclements.plus.com
Tue Nov 30 03:39:14 EST 2004
Kirk R. Wythers wrote:
> I'm running down compile errors in individual modules on grass57.cvs.
> It looks to me as if several of them are related to -lgrass_vect. For
> example, errors in both /lib/sites and /vector/v.in.ogr are indicating
> problems locating -lgrass_vect:
> truffula:~/grass5_dev/grass57_cvs/lib/sites kirkw$ make
> /usr/bin/libtool: can't locate file for: -lgrass_vect
> truffula:~/grass5_dev/grass57_cvs/vector/v.in.ogr kirkw$ make
> ld: can't locate file for: -lgrass_vect
Did this library actually get compiled?
Check the build output for the part that builds the lib/vector/Vlib
directory.
