[GRASS5] Region lock
Radim Blazek
blazek at itc.it
Tue Nov 30 10:44:06 EST 2004
Does it make sense to add region lock?
Region (WIND file) could be locked by modules until call to
G_get_window and modules changing region (d.zoom, g.region) could check
if the region is in use.
OTOH,
1) G_get_window is usually called in first rows of main()
so that user cannot start others module before it is called
2) it does not resolve problem in scripts on background which is
a real pain
Radim
