[GRASS5] Re: grass57 and 3D import
Markus Neteler
neteler at itc.it
Thu Oct 7 09:14:52 EDT 2004
Helena,
(cc to grass5 for the archive)
On Tue, Oct 05, 2004 at 11:52:30PM -0400, Helena wrote:
> I am trying to get myself started in 57 and test nviz so that it can be
> submitted, but I need some help (or maybe I should read some manual
> or tutorial).
Are you using the older Paudits version or does it already
contain the recent enhancements of 5.7/ogsf?
> To test the 3d stuff I have created a 3d point file (see below) using
> bugsites
> in spearfish (elevation is from DEM and few have points below surface)
> and imported it as
> s.in.ascii bugsites3d input=bugsitesz.asci d=3
> this creates a vector point file
I guess that v.in.ascii should be used.
"-z
create 3D file"
[ the coordinates in my example below are also for Spearfish]
echo "593493.1|4914730.2|123.1|studna
591950.2|4923000.5|222.3|kadibudka
589860.5|4922000.0|232.3|hruska
590400.5|4922820.8|143.2|mysi dira
593549.3|4925500.7|442.6|mineralni pramen
600375.7|4925235.6|342.2|mineralni silnice" | v.in.ascii -z zcol=3 catcol=0 \
out=mypoints3D columns='x double, y double, z double, label varchar(20)'
You may have to use fs= if you have different field separator.
> but v.info indicates that B and T are 0, so it must have ingored d=3 upon
> import
no, I guess because s.in.ascii is inappropriate.
I have just extended the HTML page of v.in.ascii, adding above
example.
> However, when I modified the ascii file to 3d site format and imported it
> with
> v.in.sites, it worked. But I still won't get the basic statistics on the
> file (probably my mistake as I have never used any DBM tools).
So, now we can try:
d.vect mypoints3D
d.vect mypoints3D disp=attr attrcol=label
# -> points with labels
#check DB:
echo "SELECT * from mypoints3D" | db.select
cat|x|y|z|label
1|593493.100000|4914730.200000|123.100000|studna
2|591950.200000|4923000.500000|222.300000|kadibudka
3|589860.500000|4922000.000000|232.300000|hruska
4|590400.500000|4922820.800000|143.200000|mysi dira
5|593549.300000|4925500.700000|442.600000|mineralni pramen
6|600375.700000|4925235.600000|342.200000|mineralni silnice
Works.
> GRASS 5.7.cvs:/data/b_usr4/b_usr4/grassdata/spearfish/helena/site_lists >
> v.univar bugsitesz3dt col=1
> WARNING: Incompatible types, only number of features, minimum, maximum and
> range can be calculated
> DBMI-DBF driver error:
> SQL parser error in statement:
> SELECT cat, 1 FROM bugsitesz3dt
> Error in db_open_select_cursor()
> ERROR: Column type not supported
Yes, I guess that you didn't specify the column type when using
v.in.ascii (see my example above how to do that). By default it will
make every type in the DB a string as it cannot guess the column type.
v.univar mypoints3D col=z
number of features with non NULL attribute: 6
number of missing attributes: 0
number of NULL attributes: 0
minimum: 123.1
maximum: 442.6
range: 319.5
which looks ok. IMHO the warning is confusing, but this could be improved.
> g3.createwind says after it is finished -
There must have been an error (which I fixed right now in 5.3 and 5.7 CVS).
> Now run g3.region to verify the settings.
> but there is no g3.region in 5.7 (should that message just be removed?)
There is (for a few days), please update your 5.7 version.
> When I get more familiar with 5.7 and the current 3d stuff I hope that I
> will have fewer questions and rather provide some help.
Hope that it works now
Markus
