[GRASS5] [bug #2663] (grass) problems in 5.7 debianization, affecting Grass.make, Platform.make
Markus Neteler
neteler at itc.it
Thu Oct 14 08:27:52 EDT 2004
On Thu, Oct 14, 2004 at 01:15:27PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2663
> Subject: problems in 5.7 debianization, affecting Grass.make, Platform.make
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.7
> while attempting to 'debuild' grass 5.7 on debian/sid :
Not knowing anything about Debian, but is 'debuild' the
method to compile? I thought it was 'dpkg-buildpackage'.
What I tried so far is described at
http://mpa.itc.it/markus/grass57/debian/grass57deb/
"3) Alternative: How to create a binary deb (any architecture)
from fresh GRASS CVS snapshots"
> When I freshly unpacked the package, then tried a 'debuild', I encountered
> the following problem during that 'debuild' :
> Makefile:22: include/Make/Platform.make: No such file or directory
> Makefile:23: include/Make/Grass.make: No such file or directory
This indicates that 'configure' wasn't run.
> After running
> fakeroot debian/rules config.status
> ...it seemed like that particular problem was resolved. (It looks like the
> missing makefiles are being generated during the GRASS 'configure' step.)
> Then, after another 'debuild', I encountered the same error, though after
> more output -- perhaps, after the debian/rules 'clean' target was able to
> succeed.
> Again, the errors were:
> ...which wasn't so surprising, after noticing that some commands shortly
> before those errors had deleted the specified makefiles.
> (Perhaps the debain/rules file is not ensuring that the 'configure' step
> will be done before the full build?)
Maybe. How to ensure that?
> --Full Trancript--
> dpkg-buildpackage: source package is grass
> dpkg-buildpackage: source version is 5.7.0-1
> dpkg-buildpackage: source maintainer is Markus Neteler (devel)
> <neteler at itc.it>
> dpkg-buildpackage: host architecture is i386
> fakeroot debian/rules clean
> dh_testdir
> dh_testroot
> rm -f build-stamp
> # Add here commands to clean up after the build process.
> /usr/bin/make distclean
> make[1]: Entering directory `/usr/local/src/GRASS/grass-5.7.0'
[... PLEASE: don't send unneccessary compile messages.
Keep in mind that this mail is distributed to hundreds of
people who may not be interested in reading a full compilation
log. Just shorten it to the relevant parts.
> make[1]: Leaving directory `/usr/local/src/GRASS/grass-5.7.0'
> make: [clean] Error 2 (ignored)
> cp -f /usr/share/misc/config.sub config.sub
> cp -f /usr/share/misc/config.guess config.guess
> dh_clean build-stamp configure-stamp
> dpkg-source -b grass-5.7.0
> dpkg-source: building grass in grass_5.7.0-1.tar.gz
> [[[interrupted]]]
> --End of transcript--
> I don't want to go editing the debian/rules file, when I'm not sure what
> setup you're expecting.
Not us, what Debian is expecting :-)
> I notice, though, that a typical debian/rules file will contain the
> following targets:
> configure: configure-stamp
> configure-stamp:
> dh_testdir
> # Add here commands to configure the package.
> configure
> touch configure-stamp
> build: build-stamp
> build-stamp: configure-stamp
> dh_testdir
> # Add here commands to compile the package.
> $(MAKE)
> touch build-stamp
> ...and that seems to make it "just work", hehe.
> I'm not sure what would need to be done, to resolve this; I might be trying
> some hacks, to make it work, locally -- could "share my notes", then, if
> needed
Yes. Please send the updated debian/rules to me once it it working.
Then I'll update in CVS. I have no longer access to Debian so I cannot
test.
Thanks
Markus
