[GRASS5] Re: [GRASSLIST:4510] freetype compile error
Kirk R. Wythers kwythers at umn.edu
Thu Oct 14 09:06:39 EDT 2004
Hi Glynn, thanks for the response.
On Oct 12, 2004, at 2:58 PM, Glynn Clements wrote:
> Kirk R. Wythers wrote:
>> I'm looking at the following compile error in d.text.freetype. Any
>> thoughts?
>> barbaloot:~/grass5_dev/grass53_exp_2004_05_15/src/display/
> 2004_05_15? Is this code actually from May, or has it been updated
> since then?
I have never gotten around to changing the directory names. The code
has been updates numerous times, most recently just before I
re-compiled.
>> d.text.freetype kirkw$ gmake53
>>    SRC     = /Users/kirkw/grass5_dev/grass53_exp_2004_05_15/src
>>    CMD     = /Users/kirkw/grass5_dev/grass53_exp_2004_05_15/src/CMD
>>    UNUSED  = /Users/kirkw/grass5_dev/grass53_exp_2004_05_15/unused
>>    HEADER  = head.unknown
>>    ARCH    = unknown
>>    GISBASE =
>> /Users/kirkw/grass5_dev/grass53_exp_2004_05_15/dist.unknown
>>    VERSION = 5.3-cvs 2004
>> /Users/kirkw/grass5_dev/grass53_exp_2004_05_15/src/display/
>> d.text.freetype
>>    make -f OBJ.unknown/make.rules
>> gcc -I/Users/kirkw/grass5_dev/grass53_exp_2004_05_15/src/include
>> -I/usr/X11R6/include -I/sw/include -g -O2   -I/usr/X11R6/include
>> -I/sw/include -I/usr/X11R6/include/freetype2  -c main.c -o
>> OBJ.unknown/main.o
>> main.c:79: error: parse error before "library"
> It's using the <freetype/freetype.h> header from FreeType 1.x, when it
> needs to use 2.x. Presumably the FreeType 1.x headers are in
> /sw/include, which occurs before /usr/X11R6/include/freetype2 on the
> command line.
I've always been rather confused about freetype and freetype2. I
suspect that the only reason either freetype and freetype2 are
installed is for grass. If I have no other reason for having freetype
installed, would a second solution be to simply get rid of freetype
(keeping freetype2)?
> We should probably be putting $(EXTRA_CFLAGS) before $(COMPILE_FLAGS)
> in the Makefile templates (src/CMD/generic/make.mid and mk/mid.mk); in
> general, package-specific directories should be checked before generic
> directories.
That sounds like a better solution for the long term. As this kind of
problem is likely to come up again.
> A quick workaround would be to change the ordering of the -I switches
> in the make.rules file.
> Glynn Clements <glynn.clements at virgin.net>
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
