[GRASS5] v.digit and libproj error
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Oct 20 22:30:40 EDT 2004
On Wed, 20 Oct 2004 aruizro at unal.edu.co wrote:
> Hello In grass53, I execute the commando v.digit and shows the following error:
> v.digit:error while loading shared libraries: libproj.so.O: cannot open shared object file: No such file or directory
> in a mail of mailing list says this:
> Probably the link
> cd /usr/lib
> ln -s libproj.so libproj.so.0
No probably your proj library is not installed properly. Make sure it is
in a directory referenced in the LD_LIBRARY_PATH environment variable or
add the directory to /etc/ld.so.conf and run ldconfig
