[GRASS5] v.digit on GRASS5.7
Flavio Macedo
flias at ecosconsult.com.br
Tue Oct 26 09:48:32 EDT 2004
Radim,
thanks for the replay, but I am sorry.. I wasn't very clear on what we want to
do...
we want to add some of the old functionalities from v.digit (GRASS5.3) to the
new v.digit grafic interface. For instance, "Show Unlabled Lines", and so
on... in other worlds, create a button that when you click it will show the
unlabed lines.
We are using the "Digitize new line" as our guide line. But we got lost on how
the
"... -command "c_next_tool new_line"... "
works... we are assuming that "c_next_tool" is a command which takes 1
paramenter, but we couldn't figure out how this command was created and where
it is....
anyway, we are just trying to combine the functionalities of the old v.digit
with new graphic interface...
Thanks a lot..
Flavio
Em Terça 26 Outubro 2004 08:39, Radim Blazek escreveu:
> It is better to do that in QGIS:
> http://qgis.org/screenshots/grass_edit.png
> http://qgis.org/docs/userguide.pdf
> Radim
> On Monday 25 October 2004 20:43, Flavio Macedo wrote:
> > Hi all,
> > I am a student here at the UFPR (Universidade Federal do Parana -
> > Brazil). And as a class project (GeoProcessing) we are trying to develop
> > add couple more features to the v.digit (GRASS 5.7) for our class. We
> > have downloaded the latest source code with the purpose to take a look at
> > the code to try to learn more about the new v.digit module. We learned
> > how we could add new buttons to the graphical interface, however, we
> > couldn't find, for example, how the command "c_next_tool new_line" is
> > actually implemented. does it call the old v.digit code (GRASS 5.3) do
> > draw the line? if so, how is that done?
> > Thanks a lot.
> > Flavio
> > _________________________________
> > Inflex - Linux - Uvscan Antivirus
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
