[GRASS5] 5.7/Mdk10.1: r.terraflow compilation problem
Tue Oct 26 21:33:11 EDT 2004
Markus Neteler wrote:
> we just compiled GRASS 5.7 on Mandrake 10.1 successfully
> exept for r.terraflow: The error below doesn't tell me much,
> does anyone have a suggestion?
> ./IOStream/include/pqheap.h:218: error: `MMmanager' undeclared (first use this function)
I suspect that this should be MM_manager, which is declared in mm.h.
