[GRASS5] g51test-12 bugs
Kirk R. Wythers kwythers at umn.edu
Wed Oct 27 21:51:17 EDT 2004
Can anyone tell me which version of 57 the "quick demo tour
(g51test-12)" corresponds to? I am using a current build from cvs which
I just updated in the last 24 hours or so. I tried running the tour
script and found quite a few problems.
Thanks,
Kirk
screen output from ./tour
driver:dbf
database:/usr/local/share/grassdata/g51test-12/test/dbf
GRASS 5.1 test tour
Press <Enter> to continueOpening monitor
Import GRASS 5.0 binary vectors
Import 'river' -> OK
Press <Enter> to continueImport 'lake' -> OK
Press <Enter> to continueImport 'contour' -> ERROR
Press <Enter> to
continue==============================================================
Import/export ascii files
Import/export 'mcat' vector:  -> OK
Press <Enter> to continueImport/export 'multi' vector:  -> OK
Press <Enter> to
Display multi map categories
Categories of field 1
Press <Enter> to continueCategories of field 2
Press <Enter> to continueCategories of field 3
Press <Enter> to continueCategories of field 4
Press <Enter> to continueCategories of field 5
Press <Enter> to continueCategories of field 6
Press <Enter> to
Display river for selected conditions
River table:
where: quality = 'good' and flow_winte >= 50
Press <Enter> to continuewhere: quality = 'poor'
Press <Enter> to continuewhere: flow_winte < 50
Press <Enter> to
Display river flow pie chart
River table:
Press <Enter> to
Display river flow bar chart
Press <Enter> to
Import TIN
Query 'multi'
Query 'multi' with attributes
Query 'tin' (z coordinate)
Shapefiles: create definition, build topology and display
Create definition for shapefile:
/usr/local/share/grassdata/g51test-12/shp/contour.shp
in:
/usr/local/share/grassdata/g51test-12/test/vector/contour_shp
Press <Enter> to continueCreate definition for shapefile:
/usr/local/share/grassdata/g51test-12/shp/river.shp
in:
/usr/local/share/grassdata/g51test-12/test/vector/river_shp
/usr/local/share/grassdata/g51test-12/shp/lake.shp
in:
/usr/local/share/grassdata/g51test-12/test/vector/lake_shp
Press <Enter> to
Import trees, create tower (wait a moment please) ...
0
50
100
150
200
Run nviz
WARNING: G3d_readWindow: unable to find
          [/usr/local/share/grassdata/g51test-12/test/WIND3], using
default.
[/usr/local/share/grassdata/g51test-12/PERMANENT/DEFAULT_WIND3].
FATAL ERROR: G3d_initDefaults: Error reading window
Start d.m
The End
default.
