[GRASS5] g51test-12 bugs
Radim Blazek blazek at itc.it
Thu Oct 28 07:23:51 EDT 2004
Yes it is outdated, so I removed that from my page.
On Thursday 28 October 2004 03:51, Kirk R. Wythers wrote:
> Can anyone tell me which version of 57 the "quick demo tour
> (g51test-12)" corresponds to? I am using a current build from cvs which
> I just updated in the last 24 hours or so. I tried running the tour
> script and found quite a few problems.
> Thanks,
> Kirk
> screen output from ./tour
> driver:dbf
> database:/usr/local/share/grassdata/g51test-12/test/dbf
> GRASS 5.1 test tour
> Press <Enter> to continueOpening monitor
> Import GRASS 5.0 binary vectors
> Import 'river' -> OK
> Press <Enter> to continueImport 'lake' -> OK
> Press <Enter> to continueImport 'contour' -> ERROR
> Press <Enter> to
> continue==============================================================
> Import/export ascii files
> Import/export 'mcat' vector:  -> OK
> Press <Enter> to continueImport/export 'multi' vector:  -> OK
> Press <Enter> to
> Display multi map categories
> Categories of field 1
> Press <Enter> to continueCategories of field 2
> Press <Enter> to continueCategories of field 3
> Press <Enter> to continueCategories of field 4
> Press <Enter> to continueCategories of field 5
> Press <Enter> to continueCategories of field 6
> Press <Enter> to
> Display river for selected conditions
> River table:
> where: quality = 'good' and flow_winte >= 50
> Press <Enter> to continuewhere: quality = 'poor'
> Press <Enter> to continuewhere: flow_winte < 50
> Press <Enter> to
> Display river flow pie chart
> River table:
> Press <Enter> to
> Display river flow bar chart
> Press <Enter> to
> Import TIN
> Query 'multi'
> Query 'multi' with attributes
> Query 'tin' (z coordinate)
> Shapefiles: create definition, build topology and display
> Create definition for shapefile:
> /usr/local/share/grassdata/g51test-12/shp/contour.shp
> in:
> /usr/local/share/grassdata/g51test-12/test/vector/contour_shp
> Press <Enter> to continueCreate definition for shapefile:
> /usr/local/share/grassdata/g51test-12/shp/river.shp
> in:
> /usr/local/share/grassdata/g51test-12/test/vector/river_shp
> /usr/local/share/grassdata/g51test-12/shp/lake.shp
> in:
> /usr/local/share/grassdata/g51test-12/test/vector/lake_shp
> Press <Enter> to
> Import trees, create tower (wait a moment please) ...
> 0
> 50
> 100
> 150
> 200
> Run nviz
> WARNING: G3d_readWindow: unable to find
>           [/usr/local/share/grassdata/g51test-12/test/WIND3], using
> default.
> [/usr/local/share/grassdata/g51test-12/PERMANENT/DEFAULT_WIND3].
> FATAL ERROR: G3d_initDefaults: Error reading window
> Start d.m
> The End
> default.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
