[GRASS5] 5.7: XDRIVER Freetype support functional (incl Asian fonts)
yann yann.chemin at ait.ac.th
Sat Oct 30 09:25:04 EDT 2004
It is fixed when I copied the missing XDRIVER and libgrass_driver.so
from a previous installation into their respective directories:
/usr/local/grass-5.7.cvs/driver/XDRIVER
/usr/local/grass-5.7.cvs/lib/libgrass_driver.so
But still cant find what is buggy in the compilation...
On Fri, 2004-10-29 at 19:37 +0700, yann wrote:
> Maybe related...
> XDRIVER and other display drivers do not compile on fresh install from
> CVS. It has no rule to create libgrass_display.a
> The observed consequence is that monitors can not be opened.
> On Thu, 2004-10-28 at 06:13 +0200, neteler at itc.it wrote:
> > Hi,
> > with help of Huidae Cho we got the XDRIVER Freetype support
> > functional (incl support for Asian fonts).
> > Usage:
> > #Japanese Fonts (ojiya sample location from FOSS4G project):
> >  d.mon x0
> >  d.font.freetype font=/usr/X11R6/lib/X11/fonts/TTF/ipag.ttf
> >  d.vect dourokukan
> >  d.vect dourokukan disp=attr attrcol=label
> > #... displays Japanese characters in the map (atts in DBF file).
> > #Spearfish with luxisb.ttf (Sans Serif Bold):
> >  d.mon x0
> >  d.font.freetype font=/usr/X11R6/lib/X11/fonts/TTF/luxisb.ttf
> >  d.vect fields
> >  d.vect fields disp=attr attrcol=label
> > #... displays Western TTF characters in the map.
> > I'll add a screenshot to
> >  http://grass.itc.it/i18n.html
> > the next days.
> > The implementation is a code merge from 5.0-i18N, so special thanks to
> > GRASS i18n Project Members:
> > http://www.foss4g.org/FOSS4G/GRASS/nf-grass-i18n-en.html
> > - Masumoto Shinji, Venkatesh Raghavan, Nonogaki Susumu, Nemoto Tatsuya,
> > Hirai  Naoki (Osaka City University, Japan)
> > - Hagiwara Akira, Niwa Makoto, Mori Toru (Orkney Inc., Japan)
> > - Hattori Norihiro (E-Solution Service, Inc., Japan)
> > Sponsored by:
> > IPA (Information-technology Promotion Agency, Japan)
> > TODO:
> >  add gettext message support to the TCL based commands
> > Enjoy,
> >  Markus
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
