[GRASS5] [bug #2623] (grass) problem in compilation
Glynn Clements glynn.clements at virgin.net
Mon Sep 13 15:26:01 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2623
> here is the error message...
> /bin/sh: nad2bin: command not found
nad2bin is part of the PROJ library, and should have been installed
along with the rest of it. If you installed PROJ from a package, and
it didn't include the nad2bin program, check whether this program is
in a separate package.
If you can't find it, you will need to build PROJ (version 4.4.6 or
later) from source. Either that, or edit the Makefile so as to skip
this step; most of GRASS will work without those files.
Glynn Clements <glynn.clements at virgin.net>
