[GRASS5] cvs updates completed successfully.
Michael Barton
michael.barton at asu.edu
Sat Sep 18 14:58:32 EDT 2004
Paolo,
I've been in correspondence with Leonardo. I'm not sure why he (and you?)
are having problems. The first thing is to see if both commands work
correctly from the command line. Both should give you a response in the
GRASS xterminal. You must have a monitor *open* and *selected* and with a
*map displayed* in it for these to work correctly.
If you don't have a selected monitor with a map and run d.zoom (no
arguments) from the command line, it will send you to the d.zoom tcltk gui.
D.zoom -p will generate an error in this context.
If you are not getting this behavior, I wonder if you have a slightly
outdated version of GRASS 5.7. These menus only work properly with pretty
recent versions. I am running an August 31 build (Mac OSX). There have been
some improvements since then, of course, but the menus seem to work OK on
that build.
One thing I've noticed that is a bit odd. When I using files over a network,
d.zoom and d.pan may take a few seconds to open an xterm. Other times it
comes up quickly. Very subjectively, it almost seems that it takes a
slightly longer time to open the xterm the longer I work in a given session.
Don't know what is causing this delay.
Michael Barton
On 9/17/04 12:04 PM, "Paolo Cavallini" <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Mike.
> Thanks for your work. GRASS looks great now! I believe Leonardo wrote you
> about the problems we encountered with zoom, pan etc. Were you able to fix
> them?
> All the best.
> pc
> At 20:27, venerdì 17 settembre 2004, Michael Barton has probably written:
>> I want to thank Glynn, Paul, and Hamish for their advice with the arcane
>> world of the CVS.
>> I completed the updates I started a couple days ago (GIS Manager, and
>> r.univar.sh and r.shaded.relief scripts) and restored Glynn¹s prior updates
>> to scripts I had modified. As all of you noted, I cannot remove the
>> /scripts/r.univar directory. Bernard or someone else will have to do that.
>> However, GRASS should build the r.univar.sh script correctly now.
>> Michael
>> ______________________________
>> Michael Barton, Professor & Curator
>> School of Human Diversity and Social Change
>> Arizona State University
>> Tempe, AZ 85287-2402
>> USA
>> voice: 480-965-6262; fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
> Paolo Cavallini
> cavallini at faunalia.it www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
> https://www.biglumber.com
> Only free software: www.gnu.org / www.linux.org
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.4 (GNU/Linux)
> iD8DBQFBSzUm/NedwLUzIr4RAkL+AKCdTPhEQ0cEWUMdGG4hybTvocYxUQCfdNTa
> 0HUGBhgW7INizvCqzg3tT0g=
> =X9qJ
> -----END PGP SIGNATURE-----
C. Michael Barton, Professor
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
