[GRASS5] cvs updates completed successfully.
Glynn Clements glynn.clements at virgin.net
Fri Sep 17 21:33:11 EDT 2004
Michael Barton wrote:
> I completed the updates I started a couple days ago (GIS Manager, and
> r.univar.sh and r.shaded.relief scripts) and restored Glynn¹s prior updates
> to scripts I had modified. As all of you noted, I cannot remove the
> /scripts/r.univar directory. Bernard or someone else will have to do that.
> However, GRASS should build the r.univar.sh script correctly now.
Nope. scripts/Makefile has r.univar in SUBDIRS, but that directory no
longer exists.
What exactly was the reason for renaming that directory?
Glynn Clements <glynn.clements at virgin.net>
