[GRASS5] Latest install steps for Grass on Cygwin needed.
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Sep 24 04:59:10 EDT 2004
Hello there
On Thu, 23 Sep 2004, Stephen Clark wrote:
> I am working on installing Grass 5.3 under Cygwin and cannot get the X
> windows installation to work.
Are you using a recent version of Cygwin with the new X.org X server? If
so make sure and install the XFree86 compatibility package (it is not done
by default). What exactly is the problem?
> I also have some older Grass versions that do not work correctly and I would
> like some help uninstalling these Grass Versions.
rm -rf /usr/local/grass5
rm /usr/local/bin/grass5
check paths carefully but that should be all there is to it.
> Could someone post some links to installing Grass 5.3 under Cygwin.
Some notes here:
http://www.geog.uni-hannover.de/grass/grass53/binary/mswindows_cygwin/
and also item 1 here:
http://www.geog.uni-hannover.de/grass/grass50/binary/windows_cygnus/cygwin_grass50bininstall.html
has the list of Cygwin packages you need to install, which is important.
Paul
