[GRASS5] vector point extract script
    Hamish
    hamish_nospam at yahoo.com
    Tue Apr  5 07:52:44 EDT 2005
> >>paste is probably dangerous, a record aor point can be missing.
> >Isn't >it better to use join (input must be sorted;
> > Yes it is; thanks. Script updated to use sort+join.
> >>use -e for attributes)?
> > Use -e where? for what?
> To print lines with missing attributes in join.
You mean if you have 1000 vector points but only 800 records in the
db table? I don't have any data to test that.
Hopefully -e defaults to "" then?
Hamish
