[GRASS5] [bug #3146] (grass) NVIZ: limitation regarding volume data
Request Tracker
grass-bugs at intevation.de
Tue Apr 5 16:06:32 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3146
Subject: NVIZ: limitation regarding volume data
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 6.1CVS
NVIZ currently features a limitation for the max number of volumes.
This limit is arbitrarily set to 100, there are apparently no such limitations for surfaces, etc.
This causes strange effects and/or unexpected stops when scripting is used for batch-processing of lots of data.
It is strongly suggested to increase the default value of the variable
MAX_VOL_FILES in /libogsf/gsds.c to a significantly higher value.
Thanks,
Peter
-------------------------------------------- Managed by Request Tracker
