[GRASS5] Problem converting NAD27 to NAD83 - missing ntv1_can.dat
Craig Funk funkmeister at lynxseismicdata.com
Thu Apr 7 14:40:13 EDT 2005
> The most common cause for that error is that the points you are trying
> to re-project fall outside the area covered by the datum shift grid
> file (ntv1_can.dat). Are you sure it is the correct file for your area
> (Canada).
> If you are having trouble with the grid shift files you could try
> doing a less precise datum transformation using a 3 or 7-parameter
> transformation. Re-run g.setproj in the NAD27 location to set up your
> datum parameters.
> Paul
Thanks Paul,
It ends up that the ntv1_can.dat file did not appear to be installed
properly. Where should the file live? I placed it in etc/nad directory
of the GRASS installation and then the r.proj and v.proj commands
worked fine.
I built my GRASS install from source on a Mac G5. Is this maybe a
problem with the makefiles?
Craig
