[GRASS5] Re: [GRASSLIST:6360] Startup Error GRASS60
Fri Apr 8 23:03:52 EDT 2005
Düster Horst wrote:
> I try to start grass60 with the command grass60 and the following messages
> appears:
[snip]
> Error in startup script: couldn't read file
> "/usr/local/grass-6.0.0/docs/nviz/help.tcl": no such file or dir
> ectory
>     while executing
That bug was introduced in:
	revision 1.9
	date: 2005/01/11 13:36:59;  author: markus;  state: Exp;  lines: +34 -3
	added help button with Quick Intro
due to:
	@@ -27,6 +27,20 @@
	 source $env(GISBASE)/etc/epsg_option.tcl
	+#HTML help
>>>	+source $env(GISBASE)/docs/nviz/help.tcl
	+proc make_help_window { w } {
	+        frame $w
	+        frame $w.f2
	+        frame $w.f1
	+        pack $w -side top -expand 1 -fill both
	+        pack $w.f1 -side top -expand 1 -fill both
	+        pack $w.f2 -side bottom -expand 0 -fill both
	 proc searchGISRC { filename } {
	   global database
NVIZ is supposed to be an optional component. Please remove the
reference to $env(GISBASE)/docs/nviz/help.tcl, and anything which
depends upon it, from gis_set.tcl.
