[GRASS5] Re: [GRASSLIST:6360] Startup Error GRASS60
Markus Neteler neteler at itc.it
Sat Apr 9 01:34:32 EDT 2005
On Sat, Apr 09, 2005 at 04:03:52AM +0100, Glynn Clements wrote:
> Düster Horst wrote:
> > I try to start grass60 with the command grass60 and the following messages
> > appears:
> [snip]
> > Error in startup script: couldn't read file
> > "/usr/local/grass-6.0.0/docs/nviz/help.tcl": no such file or dir
> > ectory
> >     while executing
> That bug was introduced in:
> 	revision 1.9
> 	date: 2005/01/11 13:36:59;  author: markus;  state: Exp;  lines: +34 -3
> 	added help button with Quick Intro
> due to:
> 	@@ -27,6 +27,20 @@
> 	 source $env(GISBASE)/etc/epsg_option.tcl
> 	+#HTML help
> >>>	+source $env(GISBASE)/docs/nviz/help.tcl
> 	+proc make_help_window { w } {
> 	+        frame $w
> 	+        frame $w.f2
> 	+        frame $w.f1
> 	+        pack $w -side top -expand 1 -fill both
> 	+        pack $w.f1 -side top -expand 1 -fill both
> 	+        pack $w.f2 -side bottom -expand 0 -fill both
> 	 proc searchGISRC { filename } {
> 	   global database
> NVIZ is supposed to be an optional component.
Oh, I was sort of unaware of that.
> Please remove the
> reference to $env(GISBASE)/docs/nviz/help.tcl, and anything which
> depends upon it, from gis_set.tcl.
Why not moving visualization/nviz/html/help.tcl
to a different place? I hesitate to remove the help text from
the startup screen.
Markus
