[GRASS5] Re: [GRASSLIST:6423] r.out.gdal: Unable to convert to WKT
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Apr 14 10:14:32 EDT 2005
Hello Jachym
On Tue, 12 Apr 2005, Jachym Cepicky wrote:
> The attachment worked fine now and I confirm, it works,
> thank you:
Good. I committed a slight variation to CVS that I think should work
reliably.
> just few outputs:
> 1) for the Krovak-location
> GRASS6.1.cvs(cr-jtsk):~> r.out.gdal in=dem_srtm type=Byte out=dem.tiff
> WARNING:    OGR can't parse PROJ.4-style parameter string:
>            +proj=krovak +a=6377397.155 +rf=299.1528128 +no_defs
>            +towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56 +to_meter=1.0
>            (OGR Error code was 5)
> WARNING:    g.proj: Unable to convert to WKT
> Writing format: GTiff
> Writing type:   Byte
> Input file size is 7881, 3246
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> 2) for the xy-location (there was the problem too)
> GRASS6.1.cvs(xy):~> r.out.gdal in=dem type=Int32 out=demint32
> /usr/local/grass-6.1.cvs/scripts/r.out.gdal: line 126: [: too many arguments
> Writing type:   Int32
> PROJ_INFO soubor nenalezen pro location xy
> PROJ_UNITS soubor nenalezen pro location xy
> Input file size is 1000, 1000
> GRASS6.1.cvs(xy):~>
There will still be a problem there, as running g.proj -wf in an XY
location will print something like 'XY (Unprojected)' to stdout. This was
originally a design feature, as g.proj -p certainly should print something
to indicate that the location is XY. But probably g.proj -j (PROJ
format) or g.proj -w (WKT format) should print nothing as there is no
PROJ.4 or WKT representation of an XY location. Or perhaps is there a way
of representing it in WKT? I'm not sure.
I'll think about this a bit more but at the minute my plan is to change
g.proj so it prints nothing for an XY location if the -j or -w options are
selected.
Paul
