[GRASS5] Re: [GRASSLIST:6443] d.profile: phenology curve plotting
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Thu Apr 14 18:30:16 EDT 2005
On Thursday 14 April 2005 11:01, Jachym Cepicky wrote:
> hallo developers,
> On Wed, Apr 13, 2005 at 01:58:30PM -0400, Martin Wegmann wrote:
> > Hello,
> > is there a function which plots the phenology of a time series?
> > d.profile is doing it spatially but I would like to look at the temporal
> > curve of various raster which are a time series.
> > e.g. d.profile input=raster.jan, raster.feb, .... raster.dec and then
> > select a pixel/area in the image and receive a time profile for each
> > pixel which I selected.
> > thanks in advance, Martin
> > Martin Wegmann
> I thought, that r.profile would be the best for this problem.
> Unfortunally it works only with one raster.
> I tryed to write some patch, that makes r.profile to handel multiple raster
> files.
> before:
> r.profile in=dem_int out=- profile=106.25,893.75,866.6,139.58 res=100
> Using Resolution 100.000000
> Output Format:
> [Along Track Dist.(m)] [Elevation]
> Approx. transect length 1070.936279 m.
> 0.000000 -249
> 100.000000 -260
> 200.000000 -222
> 300.000000 -164
> 400.000000 -133
> 500.000000 -176
> 600.000000 -78
> 700.000000 252
> 800.000000 230
> 900.000000 199
> 1000.000000 28
> After:
> r.profile in=dem,dem4_int,dem3 out=- profile=106.25,893.75,866.6,139.58
> res=100 Using Resolution 100.000000
> Output Format:
> 0.000000 -249.258438 -344 -152.711473
> 100.000000 -260.661446 -280 -137.916396
> 200.000000 -222.767889 -43 125.295406
> 300.000000 -164.659004 294 93.851748
> 400.000000 -133.269469 600 112.628475
> 500.000000 -176.494114 732 132.492686
> 600.000000 -78.644163 685 129.169117
> 700.000000 252.142540 410 76.520597
> 800.000000 230.412563 18 7.827528
> 900.000000 199.797620 -116 -87.963766
> 1000.000000 28.419509 -304 -316.939340
> I thing, it could be usefull change.
indeed! it will be very useful however I would propose a graphical output as
Markus did it in i.spectral using gnuplot (x=time, y=value e.g. NDVI), which
is by the way a similar function but only for max. 8 input fields.
Martin
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax:   +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
