[GRASS5] Re: [GRASSLIST:6443] d.profile: phenology curve plotting
Markus Neteler neteler at itc.it
Fri Apr 15 06:46:09 EDT 2005
On Thu, Apr 14, 2005 at 06:30:16PM -0400, Martin Wegmann wrote:
> indeed! it will be very useful however I would propose a graphical output as
> Markus did it in i.spectral using gnuplot (x=time, y=value e.g. NDVI), which
> is by the way a similar function but only for max. 8 input fields.
You could modify i.spectral to loop over the comma separated
input map names to make it sort of independent of the # of
input maps.
Shouldn't be difficult, as adding
 #% multiple: yes
will enable multiple input maps. Etc.
Markus
