[GRASS5] r.support
Markus Neteler
neteler at itc.it
Fri Apr 15 04:36:27 EDT 2005
On Thu, Apr 14, 2005 at 09:22:57PM -0700, Brad Douglas wrote:
> Let me know if you are still having trouble. I believe it's a null
> dereference in G__find_file(). I just pointed a pointer to it, which
> should stop the segfault.
> I've tried it again and again with all option combinations and I still
> fail to crash. Odd.
It still crashed, but I have applied this fix to CVS:
front.c:
/* Parse command-line options */
- if (G_parser(argc, argv)) {
- G_warning(_("Unable to parse arguments."));
- G_usage();
+ if (G_parser(argc,argv))
+ exit(1);
I remember darkly that G_usage() should not be used any more.
The old code was from 5.x...
Now it works.
Markus
